Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Pushbutton 727 Torqueflite Question
  #16 (permalink)
Old 04-15-2013, 01:34 PM
33Willys77's Avatar
33Willys77 33Willys77 is offline
'64 and '65 lever-shifted Mopar automatics are controlled by two cables (one shift, one park), just like '64 and earlier pushbutton units. They attach to the transmission the same, whether there's a lever or a set of buttons and a park slider on the other end. There is an internal difference between button- and lever-shifted cable-operated Torqueflites: the manual valve for lever-shifted units has a second Neutral position on the other side of Reverse, so the manual valve positions are N-R-N-D-2-1. The button-shift units have only the one Neutral position since the park slider engages the Neutral button, so the manual valve positions are R-N-D-2-1. In both cases, the park lock is separate. The rod-shift transmission's first year was '66.
The Following User Says Thank You to 33Willys77 For This Useful Post:
thinwhiteduke (04-17-2013)
