Pushbutton 727 Torqueflite Question - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 04-15-2013, 02:34 PM
33Willys77's Avatar
'64 and '65 lever-shifted Mopar automatics are controlled by two cables (one shift, one park), just like '64 and earlier pushbutton units. They attach to the transmission the same, whether there's a lever or a set of buttons and a park slider on the other end. There is an internal difference between button- and lever-shifted cable-operated Torqueflites: the manual valve for lever-shifted units has a second Neutral position on the other side of Reverse, so the manual valve positions are N-R-N-D-2-1. The button-shift units have only the one Neutral position since the park slider engages the Neutral button, so the manual valve positions are R-N-D-2-1. In both cases, the park lock is separate. The rod-shift transmission's first year was '66.
The Following User Says Thank You to 33Willys77 For This Useful Post:
thinwhiteduke (04-17-2013)
  #17 (permalink)
Old 04-17-2013, 02:50 PM
thinwhiteduke's Avatar
Living In The Past
That's very interesting mate, who would have thought? thanks for that. Sounds like ill be sticking to the button shift, seeing as I have the compatible valve body for that shift. Cheers..
Duke
torqueflite 727 starts in 2nd Overdriv Transmission - Rearend 16 05-23-2010 11:31 PM
727 torqueflite linkage htaplymouth Transmission - Rearend 1 09-02-2009 10:53 AM
727 pushbutton linkage qool58 General Rodding Tech 2 12-10-2007 10:27 AM
727 torqueflite engine swap question qool58 General Rodding Tech 1 12-01-2007 10:10 PM
727 Torqueflite Problem Quickhemi Transmission - Rearend 4 01-01-2006 09:18 AM
