pushbutton transmission - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-20-2007, 06:09 PM
I have a 1958 Mercury Turnpike Cruiser and would like to pull the transmission. How do I get the pushbutton cable out of the transmission?
Bob
Old 08-20-2007, 09:04 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Bob
have you removed the trans pan?
Old 08-21-2007, 07:30 PM
Pan removal
Thanks Crosley,
I was hoping that wasn't the answer. The transmission is just hanging by rope because the engine is missing. To take the pan off I need to stabilize transmission.
Would you know what engines will bolt up to this pushbutton transmission?
Old 08-22-2007, 07:30 AM
aka Duke of URL
The shift lever is actuated by a cable. Does it appear the cable(s) actuate shift lever(s) from the outside of the main case or do they appear to actuate from inside?
Regardless, you need to stabilize and support the trans as the cables will be stretched and getting them adjusted properly will be a nightmare. A description of and repair information is included in a TRANSMISSION SHOP MANUAL for the 58 MERC and is still available (35.00).
The US based TPC had either the 383 or 430 MARAUDER engine. The early MEL (MERCURY-EDSEL-LINCOLN) engine series had the same bell pattern as the FE.
Name:	1958 MERC MULTI-DRIVE KEYBOARD CONTROL.jpg
Old 08-22-2007, 07:47 AM
you must remove the pan to get the clip out, 1957 was the same. cliff
Old 08-22-2007, 11:25 AM
aka Duke of URL
THANX CLIFF!
Old 08-23-2007, 06:12 PM
Pushbutton transmission
Thanks everyone for the input!!! I will try and post how things go. Now I have to search for an engine. The 383 from what I hear is hard to find, so I guess we will have to concentrate on the 430.
Old 08-23-2007, 07:37 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
glad the answer is take the pan off.
Old 08-24-2007, 12:07 AM
aka Duke of URL
You're just strutting your knowledge and experience...
Old 08-24-2007, 06:14 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
actually it was a WAG ....
Old 08-24-2007, 07:48 AM
430 383
the 383 and 430 are the same famly and look identical, 1 clue is most 383s had a 2 brl carb i have never come acros a 430 that did not have a 4v carb
Old 08-24-2007, 08:59 AM
aka Duke of URL
...the 383 and 430 are the same famly and look identical, 1 clue is most 383s had a 2 brl carb i have never come acros a 430 that did not have a 4v carb
You will find the 383/430 had 4V until 1960 when they (MEL Division) went 2V across corporate (LINC-MERC except BIRD). LINC brought back the 4V in 1963.
As an example, in 1958 there was a LOW-TORQUE and HIGH-TORQUE 383 MARAUDER and the HP difference was carburetor CFM. The MEL Series (LINC-EDSEL-MERC-BIRD) were all considered luxury/performance until the 1960 model run when FORD tried to appeal both lines to a new market.
The 312 2V was the economy engine choice for MERC (1958-1960).
94 Dodge Transmission Electronics problem? Native Gearhead Transmission - Rearend 7 10-17-2006 10:00 PM
Hotrodders Knowledge Base: Transmission - Rearend Jon Transmission - Rearend 0 11-26-2005 06:23 PM
transmission oil type. TVR383 Transmission - Rearend 3 06-05-2005 09:28 AM
Transmission Information. M&M CUSTOM Transmission - Rearend 1 08-24-2004 03:15 PM
83 Z28 Transmission - YIKES! crandaz28 Transmission - Rearend 4 11-25-2003 07:43 AM
