pusher fan with probe sensor and sender too? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-01-2010, 01:42 PM
Footstomper
Last journal entry: 40 ford/cadillac coupe
I bought a flex fan with relay, probe to be inserted into the water jacket. I have a 500 cadillac, but I do not have a temperature sender to the dash gauge. The intake is now a eldebrock aluminum, and no place for the temp sender. I have the fan wiring complete, except pulling a plug on the driver front of the block. The question is, can that probe use as a sender and dash guage at the same time? Why not?
Old 01-01-2010, 02:12 PM
Joe G's Avatar
Originally Posted by Footstomper
....can that probe use as a sender and dash guage at the same time? Why not?
No it can't.
Because the gauge needs a sender that varies the signal as the temperature changes - sort of like a dimmer switch. But the temp probe for the radiator fan is a simple on-off switch.
Hope this helps...
Old 01-01-2010, 03:39 PM
302 Z28's Avatar
Temperature probe is a changing resistance sensor. As the temp goes up the electrical resistance changes. The fan sensor as explained is simply an on -off switch.
Vince
Old 01-01-2010, 04:08 PM
Footstomper
Now, is the time to go to LOWEs.
I finally pulled a 3/8" plug on the front of the block (drivers' side), I will need an adapter to insert the probe sensor. If I can pull the 2" plug 6" away from the other plug. I will put a flathead temperature and oil sensors with adapters. My gauges are 12V, they are 1940.
I appreciate your experience, it is somewhat like a rheostat. I am going as you say.
