Pusher or Puller ? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 08-11-2006, 07:29 PM
fan
I learned an expensive lesson. 36 Ford/SBC. Installed a Brassworks 3.5" core, two 10" pullers/shroud.(not enough room for mechanical) Ran about 205 around town, but once on the hiway temp just kept climbing. Installed a Walker, thinner core, 17" mechanical fan/shroud- 180 on the hiway, maybe 205, long idle,air on,100 ambient. Bill
  #17 (permalink)
Old 08-13-2006, 10:16 PM
oldguy829's Avatar
Last wiki edit: Swapping to rack and pinion steering
Last journal entry: 53 coupe
Wiki Edits: 88
pusher or puller
Unless I missed it....41 Coupe What?
You must be talking ford coupe. The GMs came with inline 6's and should have plenty of room. Like many people said - go with an engine fan if you can, they just plain pull more air. As far as your concern about the radiator size, quality, condition etc. No fan setup will cure that. The Walker setup with the built in conderser etc. is a sweet unit. I think they are over $600. For our 41 Pontiac coupe, I took the radiator to a shop that pulled the top and bottom off, put a new 3 row core in it, for $300. Looks stock, but they claim at least 40% better cooling than when the original was new. I was looking at, at least, cleaning and flushing and repairing the old one. I too have a budget, but this was money well spent. I ran it twice with no thermostadt, just to see how well it performed. Never got over 140 degrees, and I'm in Texas.
(actually, I think they quoted around 250 for most radiators, but our 41 was very tall so It was a custom job).
Homemade transmission pump puller bugsdad Transmission - Rearend 23 05-29-2007 01:52 PM
bearing puller hotrod69 Transmission - Rearend 3 03-24-2006 09:22 PM
Electric fan, pusher, puller 39chevy General Rodding Tech 2 04-30-2004 08:14 PM
Does anyone know a place to buy a hub puller? Magnus_Jager Suspension - Brakes - Steering 4 10-05-2003 12:55 PM
Puller Fuel Pump??? juveteach Engine 0 08-04-2003 07:52 PM
