Pushrod help - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-05-2008, 10:21 AM
Pushrod help
I am using some parts that I had around to wake up a marine 350 for my BIL,s boat. THe short block has about 50 hours on it and is the standard marine 350 with -16 cc dish pistons. I put in a XM256H cam and lifter kit, and Vortec bowtie small port heads. My question is: will the pushrod length be the same as the original heads which were casting number 14094093?
Old 10-05-2008, 12:59 PM
GMC boogie's Avatar
Of course your always suppose to check for correct geometry,but if you are replacing a hydraulic flat tappet with that cam....they are the same length.
Old 10-05-2008, 08:57 PM
Thanks for your help.
Valve Lash adjustment hiball Engine 36 05-11-2009 10:12 AM
sbc pushrod measurement GMR Engine 2 05-20-2008 05:33 AM
SBC Pushrod lenght advice needed... chevy_power427 Engine 12 02-16-2008 01:00 PM
G body with manual brakes - it works! - pics dh79 Suspension - Brakes - Steering 7 08-27-2005 10:55 PM
Pushrod Recommendation DTL504 Engine 1 05-18-2004 11:28 PM
