Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Pushrod length
Thread: Pushrod length
Old 03-30-2013, 11:09 PM
cdminter59 cdminter59 is offline
Pushrod length
This adjustable pushrod checker should get you the correct length pushrods. COMP Cams Hi-Tech Pushrod Length Checking Tools 7702-1 - SummitRacing.com. The stock flat tappet pushrods are 7.800". OEM roller cam uses 7.200" pushrod. Retro roller cam uses 7.300" pushrods. Most aftermarket heads use +.100" longer pushrods. This pushrod checker is 6.800" - 7.800" so it covers them all.
