pushrod length - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-11-2003, 12:44 PM
kellogs's Avatar
Cool pushrod length
how big of a cam can you install in a 400sbc before you need to use longer or shorter pushrods? i put a comp. extreme enrergy274/286 .487/.490 in my motor and didn't have the block decked or have the heads milled
Old 01-11-2003, 02:23 PM
mustang66maniac's Avatar
Ford Freak
Post
The only time you need shorter or longer pushrods is if you put a different rocker arm configuration on your cylinder heads. The size of the cam doesn't determine how long of pushrods to use.
Old 01-11-2003, 02:38 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
Post
The base circle of the lobes on the cam do. You can get a tool for about $6 from PAW. It looks like a mock rocker arm setup, and is very simple to use. You can't really go by the lift of the cam to determine the pushrod length.
Old 01-11-2003, 03:21 PM
Post
ROCKER ARM GEOMETRY DEPENDS ON DIFFERENT FACTORS HEADS OR BLOCK BEING MILLED BASE CIRCLE OF CAM YOU CAN CHECK BY HIGHEST VALVE LIFT COMPARED TO CAM LIFT OR USEING ROLLER ROCKERS MARK CENTER OF ONE ROLLER TIP AND CENTER OF VALVE STEM SPIN ENGINE BY HAND SEE IF ROCKER MOVES TO INSIDE OF STEM AND THEN BACK TO CENTER.
Old 01-12-2003, 03:30 PM
kellogs's Avatar
Cool
thanks for the info.i an using full roller comp cams steel rockers on afr heads <img src="graemlins/pimp.gif" border="0" alt="[pimp]" />
