Pushrod length - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-03-2005, 02:13 PM
The Brick
Pushrod length
Im puttin in a cam and all that good stuff. With this roller cam and roller lifters i need shorter push rods. its an edelbrock cam, and i am gettin comp roller lifters. Edelbrock told me they use 7.122" pushrods, and comp told me 7.178" I dont know if that little difference would matter. I was thinking about just going between those two with a 7.150" pushrod. I know there is a little tool to check i was just wondering if anyone had already done this to therir car. It a chevy 350 cam has 539 lift and 296 adv. duration. I am retro fitting a non roller block with all roller stuff. Thanx!
Bob
Old 04-03-2005, 02:38 PM
lluciano77's Avatar
I would go with Comp's recommendation. The lifter will dictate the necessary pushrod length, not the cam lobe.
Old 04-03-2005, 03:45 PM
Jmark's Avatar
Find the tool and do it right. There are adjustable pushrods or the plastic piece that you slide down the stud and ck the length.
I used a mild Crane cam, stock heads and shaved the block .020. Put on Crane roller rockers and checked and my stock pushrods were .100 too long for that setup. Anyway, don't skimp now and take a chance. Taking a good guess won't cut it.
Old 04-03-2005, 03:51 PM
The Brick
Ya thats what ill do. Thanx
pushrod length on scj heads hardrod40 Engine 1 09-04-2004 06:10 PM
Pushrod Length Checker ? DTL504 Engine 3 05-16-2004 02:59 PM
confused on pushrod length. Jmark Engine 11 11-16-2003 04:35 PM
pushrod length question for pontiac 400 steppenwolf Engine 4 12-24-2002 10:22 AM
