pushrod length - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-05-2006, 09:43 AM
pushrod length
hi there, i am using comp cams retro fit roller lifters and just recently got an awesome deal on comps pro magnum roller rockers. the only problem is that they are 1.6 ratio. is there anyone using this combo, or anyone that can tell me how much my pushrod length is going to change? this is a '76 sbc 355
thanks for your time.
keith
Last edited by classic keith; 03-05-2006 at 05:07 PM. Reason: did not specify application
Old 03-05-2006, 11:25 AM
The rockers would not affect the pushrod length. But they may cause pushrod clearane issues. Intall the rockers and rotate the motor by hand and check for binding, spring clearance.
Old 03-05-2006, 05:08 PM
thanks for the tip. i will be sure to check that!
keith
Old 03-05-2006, 05:14 PM
steve t's Avatar
ex biker, now hotrodder
if anything they may rub the push rod holes in the head, i run them on my 283 with no problem
Pushrod Length ProjectSuperNova Engine 5 02-16-2005 11:22 AM
pushrod length on scj heads hardrod40 Engine 1 09-04-2004 05:10 PM
Pushrod Length Checker ? DTL504 Engine 3 05-16-2004 01:59 PM
pushrod length question for pontiac 400 steppenwolf Engine 4 12-24-2002 09:22 AM
