Pushrod Length Checker ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-15-2004, 06:23 PM
84 Z28 Convertible
Trick flow has several sizes that are offered from Summit. My block has been deck very close to .000-003 deck height. I thought by decking the block I would need a shorter pushrod, plus I got the upgrade valves that is .100 longer. So which length push rod checker will be right with all these variables I have?
Which pushrod length checker should I use?
Trick Flow Specialties
TFS-9000 6.125 in. to 7.500 in. long, 5/16 in.,
TFS-9001 7.500 in. to 8.700 in. long, 5/16 in.,
TFS-9002 8.700 in. to 9.800 in. long, 5/16 in.
TFS-9003 9.700 in. to 11.000 in. long,5/16 in.
TFS-9004 10.200 in. to 11.500 in. long, 5/16 in.
Old 05-15-2004, 06:49 PM
Hard to say without knowing what engine you are working with. You can make your own by taking a push rod from your motor, cutting about 3/4 inches out of one end about 4/5ths of the way up, threading the long and short pieces and run a stud in with nuts to make it lock in place. Now you have your very own that will work as good as any you buy. Now you just need a good mic to measure your checker after it has been adjusted to the correct length.
Trees
Old 05-15-2004, 08:08 PM
84 Z28 Convertible
Here is my combo.
84 Z28 SBC 408
Scat 4340 Crank,Wiseco Piston,Eagle 6"H-Beam Rod,UDHAROLD-280/284F10,AFR-195,1- 5/8 Hookers,Pro-Built 700R4,3000SS, 3:73 Rear
Old 05-16-2004, 01:59 PM
SBC. If you do not want to make your own. then call Summit and tell them what motor/cam/rocker configuration and let them send you the right pushrod checker tool. I looked in my catalogue and did not find one listed, but they have them.
Trees
