pushrod lengths - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-19-2003, 07:47 AM
Post pushrod lengths
When measuring for push rod lengths on a new motor with a hyd.roller cam can do you need to use a solid roller lifter or will any solid lifter do for determinig the proper length.thanks
Old 01-19-2003, 08:23 AM
BOBCRMAN@aol.com's Avatar
Post
you must use the same lifters that are in the motor, to get them to pump up soak them overnight in a can of engine oil, then take a pushrod and press down on the seat in the lifter while submerged in oil, do this untill no movement is felt. then install in engine and measure your correct length, the rocker must stay as close to the center of the valve as possible, starting on one side of center at rest then centered at 1/2 lift and over center at full lift, adjust pushrod length accordingly, allow for about 1-1 1/2 turns down for preload on the lifter.
Old 01-19-2003, 10:24 AM
Post
Hey thanks a bunch BOB. By the way im from Davison were practicaly neighbors.
