Pushrod springs and shocks
This is the type where a pushrod acts on the spring and shock thru a bellcrank...Has anyone built one of these??? Tips would be appreciated..
Sam
Like this one?
![]() I never built one, but I'd be looking that that one for inspiration.. I know that Ron Attebury builds one as well, his is similar to the Kugel. Later, mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example |
That is the type..mainly I am interested in fabricating the rod and bell crank assemble as I have the rest of it..I wonder what size bearing was used for the pivots and how big that push-rod is?? Maybe we can work up a HR.com do-it yourself deal..
Sam
I have tried most all of it and now do what is known to work.. Last edited by OneMoreTime; 11-11-2007 at 03:39 PM. Reason: spell check |
I'd use a 5/8" shoulder bolt with a 3/4" OD bronze bushing pressed into the crank. Drill the bellcrank and put a zirc for greasin it up.
I wouldn't use a bearing, too many little jarring impacts would tear it up, and you would need to make the bellcrank fairly large at that end to accomodate the OD of the bearing. I'd use a solid bronze bushing instead of the oilite type. I'd think that 3/4" or 7/8" heavywall tube would be plenty for the strut as long as the car is an average weight. What are you putting this under? Later, mikey
I am putting it under my roadster...putting the coil overs in the stock location results in something Oggglly so I thought the remote install would look better..Might even be easier (really) to fabricate..Now it is off to McMaster Carr to get some more oilite bushings and another reamer..I think 0.120 sheet should be adequate to cut the bellcranks out of..I will use the 0.50 bushings for the rod ends that I will make..
Sam
The bellcranks will be .120" sheet on each side, and connected by a through tube with the pressed in bushing for the pivot and sandwiching the rod ends on either end, correct? That should be plenty strong Later, mikey
Yup..that is the way.. Sam
| Chopping coil springs | Poison Heart | Suspension - Brakes - Steering | 37 | 10-19-2007 12:33 PM |
| Delphi "De Carbon " Struts / Shocks & Springs | Rob Keller | Suspension - Brakes - Steering | 6 | 06-10-2007 11:12 AM |
| Rear Drag Shocks on a Street Car? | JohnTN | Suspension - Brakes - Steering | 2 | 08-09-2005 04:25 PM |
| sizing rear shocks with leaf springs | 1940chevy | Introduce Yourself | 1 | 01-06-2005 11:58 AM |
| springs and shocks? | chevelle327 | Transmission - Rearend | 0 | 11-20-2002 06:54 AM |
