Pushrod tubing diameter - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-27-2009, 05:59 AM
The pushrod tubing diameter on a sbc is 5/16 right? Just making sure
Thanks David
Old 05-27-2009, 10:38 AM
Does anyone know
Old 05-27-2009, 11:09 AM
Thanks David
OEM is 5/16s, performance option is 3/8s. Ends are the same for either. If passing thru a guide which will happen for all except self guided rockers, the tubes must be hardened for wear resistance.
Bogie
Old 05-27-2009, 12:39 PM
Stocker yes 5/16, but you can use bigger depending on you needs right on up thru 7/16 if necessary. Pushrod length and diameter are directly related to pushrod deflection under load - high lift & pressure. Using the stiffest pushrod is always your best move.
Making dies and rollers to bend square tubing cboy Garage - Tools 20 11-05-2012 05:59 PM
How To: Tubing Bender Twisted Minis Garage - Tools 65 11-18-2008 04:09 PM
1.6 Rocker arms and maximum spring diameter Fishgrinder Engine 3 04-07-2008 12:09 AM
SBC Pushrod lenght advice needed... chevy_power427 Engine 12 02-16-2008 01:00 PM
Exhaust tubing diameter NovaSS350 Engine 4 03-20-2006 12:21 AM
