PushRods Hardened Steel vs Chromoly - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-24-2011, 04:25 PM
001mustang's Avatar
I have guide plates, 308 lb/in rate springs w/ <295 lb max lift pressure.
PR length is approx 8".
Hyd flat tappet.
I'm setup for 5/16" OD ball socket PR.
I have run the hardened steel before; i don't know if they flex, dance or behave?
I do know they get along w/ guide plates for a long time.
Would be nice to buy the cheaper hardened steel push rods.
Any comments?
Old 02-24-2011, 04:45 PM
ericnova72's Avatar
More for Less Racer
Your not into the territory on spring pressure high enough to make qne-piece chrome moly absolutely neccessary, but it never hurts to have a pushrod much stiffer than is really needed.
Your application I would use plain aftermarket hardened with welded ball ends unless I was going to shoot for 7200-up rpm on a regular basis.
Old 02-24-2011, 05:21 PM
001mustang's Avatar
my pocket book likes that answer.
i'll try to keep it below 7 grand
Old 03-06-2011, 10:36 PM
001mustang's Avatar
had to go w/ chrome moly because they were only ones available w/ length i needed for proper geometry...they sure are pretty.
chromoly tubing dougfromredhotrods General Rodding Tech 5 02-29-2008 11:58 PM
hardened pushrods pi71 Engine 4 08-11-2007 06:29 AM
TIG Welding Chromoly Mikey_mike General Rodding Tech 5 04-30-2006 04:03 PM
hardened valve seats stfinney Engine 2 11-12-2002 11:27 AM
Hardened valve seats?? stereodud Engine 12 11-02-2002 10:15 AM
