Put front disk brake on my 1970 parisienne - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-28-2005, 11:19 AM
Parisienne70's Avatar
i have 4 drum brake and i want put front disk brake, what early car i can take disk brake for the conversion
thank you
Éric
Old 11-28-2005, 10:03 PM
For those south of the border, that's a full-size Pontiac (Catalina, etc.).
Old 12-03-2005, 06:55 PM
junkyardjeff's Avatar
I would think discs from a 69 or 70 impala would work,71 and up might work but they have a bigger bolt pattern for the rims. They might be hard to find but there are companies that make disc conversions but they are pricey. Jeff
Old 12-05-2005, 09:26 PM
Pontiacs had the big lug bolt pattern back then, so Impala rotors wouldn't work, and I'm fairly certain the suspensions are not the same. You'll probably need to use '70 full-sized Pontiac stuff, although the years immediately prior might also work. '69 was the first year for the single-piston calipers, which seem to be a lot less troublesome than the old 4-piston ones.
Full-sized Chevys went to the big bolt pattern in '71, when all the big cars got the same new suspension design.
Old 12-06-2005, 03:55 PM
I thought the canadian pontiacs were built on the chevy chassis,they were in the 50s and 60s. Jeff
disk brakes front 40 chevy B Butcher Introduce Yourself 3 11-18-2005 03:33 PM
body panel alignment gmonkey Body - Exterior 5 09-01-2003 06:50 PM
Front runners..will draglites brake on the street??? Mrss69camaro Body - Exterior 0 05-28-2003 04:54 PM
disk brake swap CARGUY Suspension - Brakes - Steering 0 07-22-2002 12:52 PM
front disc brake wheel cylinder??--bleeders Tom34ford Suspension - Brakes - Steering 2 06-03-2002 04:02 PM
