Sounds to me like a recipe for a disaster..what I do is to lay the fabric down an get it positioned where I want it then fold half of it back and lay down my adhesive..then i carefully take the folded half and lay it into the adhesive and working from the center rub the fabric in..that way I chase any bubbles or wrinkles out to the edge..then I do the other half fold it back lay down my adhesive and then lay the other half down..once it is glued then I can turn my edges and the headliner is ready to go..
Just my way..others may have a tip or two.. Sam
Never heard that one before.
Please post how your headliner install goes. I have one to do myself. |
installing headliner
Hey, for once I may have an answer for installing headlined with bows.
I installed mine on a 66 Nova in about one hour with help of wife. Used no glue............. install bows carefully into slots in headliner. start at front and install bows into slots one at a time position headliner carefully (spread it) Next (I purchased moulding (edging) from J>C> Whitney) Cut the moulding into 1 inch pieces. Use these to clip headeliner into fron and rear and side track. To do this: Start clipping center front and then center rear. Then left and right side front and same rear. Use this clips to hold headliner as you work along the sides front to rear. Now clip across the front and then the rear. reposition as necessary to smooth out the headliner. Also clip the sail panels down the rear. Once the headliner looks reasonably smooth (it will have wrinkles from packaging and slight loose areas from installing) STOP any more fooling around. Let it sit for a week in warm weather. Now......reclip as necessary to really smooth it out. You will still have spots that bother you. Not to worry. If the car can sit in the sun for reasonable period the headliner will shrink perfectly into place. Now you can remove several clips at a time and the liner will still stay in place all by itself. Finish the edging as you wish. Glue or whatever. I edged mine all the way around with the chrome faced edging from Whitney. I thought it would look a bit goofy...........it really turned out beautiful. Then I put in new buckets, carpets, door panels etc, repainted the dash and column and put on a street rod wheel. Made a radio faceplate from ABS plastic with a bit of chrome. This is a street rod, not a restoration car 375 HP and one shot nitrous.. pure fun Al..............hope this helps |
Hey - thanks for the descriptive reply. That definetely gives me some ideas. I don't quite understand what you used for molding - I guess I need to check out the JCW catalog some. If you had any pics to show, I would certainly appreciate that! And what is this "chrome faced molding" that you got a hold of? Is it still flexible and all or what? |
Okay, I thought the 30 min sounded crazy, the instruction that came with say nothing about that so I was a little leary of it. Plus, how would I get it up there while it's "hot" while still having to apply a couple coats of that weld-on glue? I think I'm going to scratch that idea. Would it be okay to gently heat with my heat gun to take out some of the wrinkles? One thing that has me stumped is toward the top of the "sail panel", there is a metal strip that is held on with two screws, one at each end. This strips spans an open area in the inner sheet metal, and looks like something was glued to it. I'm thinking that I need to use these strips to glue the headliner material to. Is that right? It seems that is the only thing that makes sense, but then again I've never done this so ???? |
headliner install
Just go for it.............forget the oven or micro
Dont know if your edging is the same as a 66 Nova........but JC Whitney 1-800-529-4486.......call for catalog Under "weatherstripping" Interior/exterior trim 1/8-3/16 style "D" flexible trim. The Nova has "Raw" edges on the doors and around the edges where the headliner goes. If your car is not similar you will have to use your imagination a bit. My headliner turned out perfect.........not a wrinkle. beginners luck? Al......in the biggest little city in the world Also...have to brag to someone.........had a crinkled fender.....never done body repair.......bought a "shrinking disc" from a fellow in Washington State. Fender turned out 98 percent....used a skim coat of putty. With a bit more patience could have avoided putty. |
headliner install
Top O the Mornin
Shrinking disc.............use it on a 7" grinder........apply it to a stretched area for about 10 secionds.....then quench with a wet rag...........this thing works. Do a google for (ghia specialties.com) or email (ghiafab@coastaccess.com) or........call the man....John Kelly 1-360-276-0014 I bought his standard disc with a 15 minute instruction video for 40 dollars and free shipping. I also tried to make a disc from stainless pot lid..........gave up on this idea, broke down and bought the real thing. Al.........in the biggest little city in the world |
| Recent Interior posts with photos |
| Headliner help. | Javelin360 | Interior | 10 | 07-24-2006 10:46 AM |
| headliner board | pepi | Interior | 3 | 01-05-2006 09:52 PM |
| Headliner gripper strip question on my 49 Fleetline | Rodrunner | Interior | 2 | 05-27-2004 07:41 AM |
| Headliner. | M&M CUSTOM | Interior | 3 | 04-01-2004 05:42 AM |
| S-10 Headliner trim pieces?? | TurboS10 | Interior | 4 | 02-08-2004 05:54 PM |
