I hope to God you mean a 302 chevy- which is quite rare. And a TH400 is way overkill for that engine, nonetheless, you shuold be able to use a regular conversion kit from Summit.
Why? Sure, it's easy, and the kits are avaliable for a SBC swap, but the SBF in a s-10 would be a head turner.... |
But an SBF on a TH-400 transmission would be a lot of work for no gain. There are plenty strong Ford transmissions that would bolt right up with no adapters.
Adam, for the easiest engine swap, always get an engine and transmission together. If you want to use a 302 Ford that's fine, but I'd get an engine with a transmission. If for some reason you want a different transmission, look at the engine manufacturers choices that will bolt right up. It's a lot easier to change mounts than it is to adapt transmissions. In general, you don't want to adapt a transmission that isn't made to bolt up to the engine unless there are no transmissions that will easily bolt up and do the job you want. |
Read it again guys...4th sentence...he asks "can i cut out the mounts in my old Ford frame"??? i think that says Ford all over it...sorry i don't mean to be a wisea**... I don't mean to "dog" anybody but as a matter of preference i'd stick with a GM motor...i'm all for the "Dare to be different" cause...but i'm just bias toward GM/Chevy...i don't like popping a hood & the first thing i see is the distributor cap & a bunch of wires...Kimo |
I put a 350 in a 1988 S-10....pain in the backside...but sure was fun. If I was going to take the time and effort I would sure go with a 350 or 400 with a TH350 or 400. Watch the clearance on the tranny and you will have to get custom headers and mounts....Summit or Jegs has them. Jump on their site and search.....you didn't mention the trucks year. Not an easy swap you'll definitely get an education if you're a beginner.
for the amount of money and many many many many hours it will take...forget it
sell the 302, buy a 350, the whole project will cost less at the end and it's a proven swap of standard (?) parts ha! want to be blue oval....stick some Ford badges on the body....now that would be a head turner! |
I'm SORRY
I have a c4 transmission. Guess I was still thinking about an artical I read before I posted. This should make it alot easier project to do and talk about. My plan is to install the engine and transmission in the s10 and then mount my 51 f1 ford on top of it.
Ahhh...well this change's everything doesn't it... ...here we are getting into the old Chevy vs Ford debate & you're only useing the S-10 (frame) as a base...you're keeping it a Ford/Ford combo & body...i'm just joking...hope i didn't offened anybody out there...Kimo...
Shouldn't be too big of a deal. You will probably want to use a rear sump oil pan and pump though.
You will be making your own mounts....no kit available.....Real hotrodders dont use kits anyways.
Ontario Rodders |
If I could make one suggestion, It would be to install the body first, then the motor/trans. If you don't mind clearancing the firewall, I'd say, set the motor back and down as far as possible, which should be pretty far with no dizzy out back. I've seen to many S10's with their engines trying to pop out of the hood, and they always ask "how do I get traction?"
Another nice thing to do is, if possible, install the engine with the starter on, or at least make sure you can install and remove the starter before you start fabbing or even measuring for mounts. Try to find some IROC of GTA front springs as they ride really nice with a V8. Good luck. |
adam,
agree, "whole different" project with your additional info... agree with Poncho, (shouldn't be alot more or less hours than cutting and welding on a different frame that doesn't fit) your going to put it together and take it apart alot of times before all is just right so: LOTS of reference points marks on the body/frame/motor (magic marker-masking tape- scribe lines-etc) and measurements written down..to answer the what's and why's...and a hell of a time saver |
| 302 ford engine stalling | m.ringo | Engine | 3 | 11-29-2005 12:21 PM |
| 302 engine is stalling | m.ringo | Engine | 5 | 11-08-2005 08:01 AM |
| Cam Help | black66 | Engine | 3 | 05-12-2003 06:15 PM |
| Suggestions on Engine! | dhaza | Engine | 3 | 03-09-2003 03:35 PM |
| s10 frame question | mitmaks | Body - Exterior | 7 | 02-04-2003 03:53 PM |
