putting in arp rod bolts in bbc
happy memorial day fellows heres the problem i have today when installing arp rod bolts can you use a arbor press and press the rod onto the bolt insteadof pressing thebolt into rod and get away without having the rod resized i used the cap and nut to pull one into the rod but it turned a little bit an with a rod bolt stretch gage the way i see that gage after pulling it in and took the cap off which by the way was very very hard the bolt shrank 0.09 inch
You cannot replace the bolts and not re-size the rod!. Chances are that the rod housing bores were not perfect before the bolts were changed. The bolts being pressed into the rod distort the housing even more.
thank you for your answers all the help is greatly appreciated
| ARP Rod bolts - how much better over stock? | Mad Maggot | Engine | 22 | 05-05-2013 08:19 AM |
| Arp main bolts | cdminter59 | Engine | 5 | 01-26-2012 12:51 PM |
| Ok torqued rod bolts todaydid what arp said to do Will I be safe? | eric32 | Engine | 6 | 05-29-2009 02:57 PM |
| Installing arp rod bolts | Eric327 | Engine | 4 | 03-10-2007 05:50 AM |
| ARP head bolts | oldred | Engine | 4 | 04-01-2005 10:32 AM |
