Thanks for the replies.
Forgot to mention the subframe under the car in the pics is from a donor car because the other one was bent.Before I put either one under the car I took a lot of measurement for both and used the best one.Check out the pic (F and G) measured from both sides and both are within 1/16 to 1/8.Also pulled diagonals measurements in red from the lower control arm bolt to the rear master gage hole in the rear also within a 1/16 to 1/8 of each other.
