Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Putting it back together (72 Nova)
Old 11-27-2012, 08:10 PM
MARTINSR MARTINSR is offline
Those measurements would tell you that the sub frame is mounted to the body straight but it doesn't help you one bit as far as telling you if the subframe is square or not. You need to measure the frame it's self then go onto the next step.
Is that rad support and all the sheetmetal reproduction?
