Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Putting it back together (72 Nova)
  #20 (permalink)
Old 11-28-2012, 01:19 PM
NOVA1958 NOVA1958 is offline
Here's a pic of the dr side door, notice the gaps at the top and no gap at the bottom.I did alot of work on the dr side firewall I pulled it myself, not knowing the pillar was pushed in,now it fairly close.As for the subframe mount on the car also did alot of work so I would have more adjustment.When I first install the subframe I used the pass. side to go by because it seemed.The rear frame gage hole are right under the rear seat pan which show no damage at all.I took measurement of the rear but I've forgotten the measurements.I'm going to try and measure the rear again.I'm thinking like you guys I have more work ahead of me.Something I didn't mention was the both mounting holes in the radiator support,right and left are off like in the pic.As far as the dr door I've got it under control I'm going to do just a bit more to make it fit better and leave it alone.
