Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Putting it back together (72 Nova)
  #24 (permalink)
Old 11-28-2012, 06:59 PM
NOVA1958 NOVA1958 is offline
Here's some pics of the car right after I purchased the car, I had no idea it had been wreaked.I started with the floor pans and toe boards first then the pass. side quarter, moving on to the driver side quarter ,the only evidence of any damage was a small patch panel and some bondo on the dr.side not that bad.As for the work done on the car side of the subframe mount all I did was make the hole larger where I would have more adjustment also did the same to the dr side of the subframe mount.All I'm looking for is a happy medium up front because the sub frame has to be straight so the front bump doesn't hit either side.
Took some more measurements of the rear.
O.75 9/16
j. 75 3/8
n.64 11/16 driver side 64 13/16 pass sid
Again thank for the help.
