Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Putting it back together (72 Nova)
  #44 (permalink)
Old 12-04-2012, 06:42 AM
NOVA1958 NOVA1958 is offline
Hey guys, I have more questions.While taking a break from aligning the subframe I switched to something else.With the sheet metal align up front I figured I'd see how the bumper plastic filler fit.There are 2 of them one metal and one plastic.As you can see everything bolted up fairly easy,but the plastic top piece doesn't fit.There was no plastic filler on the car when I purchased it.I'll remove both and take another pic so you can see the metal one. Does anybody have a pic of this put together.
Something else I'd like to ask about the subframe alignment.Looking at the rear frame rail in the back the driver side does seem the be back alittle but if that was so wouldn't that make it very hard to bolt up the rear end.The leaf springs and rear axle go in as a whole and all bolt up fairly easy.
Also I noticed some of the pics I posted last week aren't showing up.
Thanks
