putting carburetor on 1984 Chevy caprices - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-19-2011, 06:40 AM
i just recent rebuild a 305 and was going to put the rochester q jet back on and i dont know how to can someone tell me step by step on how to install it
Old 07-19-2011, 06:59 AM
Clint Cummins's Avatar
hey,
Look through this thread for specifics:
Rochester Quadrajet 4MV Carburetor: Removal, Disassembly, Rebuild (Rookie Level)
Basically 4 bolts or nuts, a fuel line, some vacuum lines, throttle linkage et cetera.
Does this help any?
Old 07-19-2011, 12:19 PM
bigdog7373's Avatar
Of course it's fast
If you could rebuild the engine then im sure you can bolt a carb on top of it just make sure you dont drop anything into the manifold. Theres been a few threads lately about that. Apparently some people think that a nut will pass through the engine and come out the tail pipe! Hahaha.
Old 07-19-2011, 12:43 PM
Is this a CCC computer controlled Q-jet? If so, you need to get a factory service manual and follow the adjustment instructions EXACTLY. This system runs great if it's adjusted properly, but most people won't take the time so they run like crap.
Old 08-15-2011, 11:54 AM
i agree with bigdog7373, just don't drop anything to the manifold. just be careful in putting carb on top of it dude. oh by the way, there are some threads here in this forum that can help you out!
regards,
darren
"always use genuine carburetor to your car"
1984 chevy 1 ton need a/c bracket help. Riley Engine 8 01-08-2012 11:37 AM
Putting a 72' chevy 350 into 1995 chevy silverado that has a 4l80e trans Willbee26 Transmission - Rearend 3 03-28-2010 10:40 PM
1984 Chevy Corvette tanjabrooks85@yahoo. Introduce Yourself 2 12-07-2009 05:31 PM
1984 chevy caprice odarryl Engine 3 12-14-2005 03:07 AM
1984 Chevy C10 1/2 Ton Std. Cab Ideas Ray102386 General Rodding Tech 1 07-23-2003 09:40 PM
