We're winning the case!
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 10-07-2007, 11:50 AM
kevin3451 kevin3451 is offline
putting a chevy 350 in a 80 trans am i need help
i have a trans am with a 400 in it i think but i want to re build it and i need the car to run so i was going to put the motor out of my truck in it its a 86 chevy with a 350 will they swap how hard is it
Old 10-07-2007, 12:21 PM
DoubleVision's Avatar
DoubleVision DoubleVision is online now
2nd Gunman On The Grassy Knoll
You mean a 400 pontiac engine or a 400 Olds, 400 Chevy? A motor mount swap is in order if it`s other than a chevy engine, which is a breeze, pick up mounts for a Camaro of the same year. You`ll need another transmission, as if the engine is other than a chevy it won`t share the same bolt pattern, a TH350 short tail will bolt right in. The wiring and sensors are all a breeze also, if you had a donor camaro of around the same years it would make the swap easier, but as is the swap is simple enough. Find motor mount ears (the ones that bolt to the block) of the short variety, there were the long and the short, the long ones will make the engine sit too high in the front, the low ones make it sit just right. You can tell the difference just by measuring the distance the bolt hole is to the back of the plate. Just pick up sensors for a 80 camaro with a 350 for your gauges to work correctly. You may have to do some wire rerouting but this is a breeze also.
Old 10-07-2007, 08:01 PM
so how long will this take
will this take a long time or can it be done in a weekend,where can i get the short motor mounts
Old 10-07-2007, 08:49 PM
ernkazern ernkazern is offline
Huh
The Pontiac and Chevy engines use the same lines of transmissions. You can swap them back and forth all day with no problem. In an 80 car you'll have either a 350 or 400 turbo trans if it's an automatic. I'm not sure if they offered the 700R4 in 1980, but even so, it should fit the Chevy block.
Old 10-07-2007, 08:59 PM
fiscus fiscus is offline
fiscus's barnstar
Wiki editor
Last wiki edit: Calculating tire size
Wiki Edits: 2
This not exatly true, the bellhousing pattern is different, although there are some transmissions out there that will bolt up to both motors.
A motor swap can get pretty involved, especially when things go wrong or little things come up. They can often take much more than a weekend. Do you really need to swap the motor? why?
Old 10-07-2007, 09:07 PM
DeputyDawg134's Avatar
DeputyDawg134 DeputyDawg134 is offline
Mechanical Animal
Motor Swap
Doublevision and Fiscus are right, the pontiac tranny had the corporate bellhousing, and the chevy uses the chevy bolt pattern. I have a '79 Trans Am with a sbc in it. Swap isn't hard, but make sure you have everything you need when you get started or the small stuff will make it take forever.
Old 10-07-2007, 09:42 PM
Chevrolet4x4s Chevrolet4x4s is offline
Chevrolet4x4s's barnstar
Wiki editor
Last wiki edit: How to title a hot rod
you can get a chevy engine to bop trans adapter from speedway motors for about 40 bucks......why are you using the truck as a patrs vehicle
Shane
Old 10-08-2007, 04:35 AM
Chevy 350
I'll have to call my local tranny shop about that. I have an 85 Chevy SBC with a 700R4 that I was told came from an 88 Trans Am and it bolted right up to the block.
Old 10-08-2007, 04:41 AM
Chevy 350
Find someone that knows about transmissions to look at your trans. Many of the 350, 400, etc. trans have a "dual pattern" bolt holes and will fit any GM V8. You may be able to bolt your SBC directly to the trans you have now. If you Google it you may be able to find a picture that's clear enough so you can for yourself.
Old 10-08-2007, 06:44 AM
Old 10-08-2007, 06:49 AM
350 Engine
It's very doable in a weekend depending on your skill level and what you have for tools.
Old 10-08-2007, 06:53 AM
Btw
You never did say what trans you have in your car. The 400's aren't dual pattern, but most 350's after the mid to late 70's are.
Old 10-08-2007, 08:45 AM
fiscus's barnstar
Wiki editor
Wiki Edits: 2
If you have to ask, I bet you it will take more than a weekend, usually it does unless you're a pro. I would set your self up so you can take your time doing the job.
And an '88 trans am should have a chevy 305 or 350 in it.
Old 10-08-2007, 10:28 AM
swap
im a chevy guy i play with camaros nd bel airs this is my first trans am.... so i can get the short motor mounts out of a camaro and put them it th trans am
Old 10-08-2007, 02:17 PM
richard stewart 3rd's Avatar
richard stewart 3rd richard stewart 3rd is offline
Hi Kevin,
The 80 model TA did not have the 400 engine
option, v8s=265,301NA,301Turbo, or a 305 Chevy.,
the trans., offered for the 80 model, is the Th.350
Take care,
rich
Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "putting a chevy 350 in a 80 trans am i need help"
Distributor Tuning and Theory - Part 1 Rick WI Engine 34 07-26-2008 04:59 PM
dipstick problems with 350 trans merowe Transmission - Rearend 5 08-15-2006 03:42 PM
350 Turbo Trans greywulf Transmission - Rearend 3 03-29-2005 09:17 PM
Will this work? Chevy 305 Throttle Body w/ Chevy 350 aberg12012 Engine 9 05-07-2004 12:28 AM
putting a chevy 350 into a 1979 pontiac firebird gwarren Engine 11 02-03-2004 12:50 AM
