Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - putting a chevy 350 in a 80 trans am i need help
Old 10-07-2007, 09:49 PM
ernkazern ernkazern is offline
The Pontiac and Chevy engines use the same lines of transmissions. You can swap them back and forth all day with no problem. In an 80 car you'll have either a 350 or 400 turbo trans if it's an automatic. I'm not sure if they offered the 700R4 in 1980, but even so, it should fit the Chevy block.
