Putting in a Floorpan - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-25-2007, 08:05 PM
37Doj's Avatar
I have a 37 half ton dodge truck with virtually no floor in it. The remainder of the cab is in really good shape. I've braced the cab well from the inside and tack welded the doors in place to prevent any flexing. Not sure about how to do the floor. Do I run some kind of frame work to weld panels to ? Any tips would be greatly appreciated.
Old 03-25-2007, 08:12 PM
Welcome to the site 37Doj
I don't know what your floor looks like but here are a couple of pics of one I'm doing for my 57 chevy truck. It is made from 16gauge steel. I had to cut it and bend it to fit but it should be o.k. You may be able to do something similar with your truck.
Kim
Name:	Cab Floor #6.JPG
ID:	19842   Click image for larger version
Name:	Cab Floor #7.JPG
Old 03-25-2007, 08:21 PM
37Doj's Avatar
Floor pan
Thanks,
The pictures are a help. The floor is rusted all the way out to the bottom of the rocker panels under the doors which are still in decent shape. Once I get the floor pan in and can rock and roll on this project. I have access to a full machine shop at work also which is a plus. Good luck with your 57.
testing of new brake lines before putting car back together firstgear Suspension - Brakes - Steering 8 06-25-2006 12:13 AM
Putting patch panels in truck bed, couple questions ChevyJim Body - Exterior 20 02-10-2006 07:38 AM
Putting on new air bag steering wheel on a older steering collumn. CruisingRam Interior 10 12-20-2004 03:34 AM
Holey floorpan Batman!! tazzman68 Body - Exterior 7 04-02-2004 08:23 AM
putting 305 heads on 350 low77ride Engine 8 01-08-2004 03:43 PM
