Putting a Grand National Motor in a Cutlass - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-10-2006, 08:18 PM
ChrisMiddleron's Avatar
Hi
Im wanting to do something in one of my cars.
A buddy of mine has a old working 1985 Grand National motor in his garage. It has the turbo in the back of the motor instead of in front of the motor. What are the drawbacks of having this?
Also what transmission and rear end should I get when I put this motor in my car? Im wanting it quick from the get go.
Also what modifications would I need to make to my Cutlass to use the grand national motor? I have the brain the wiring and all the other small thinks that bolt onto the motor.
What do yall think?
THanks,
Chris
Old 01-10-2006, 08:21 PM
camaroman7d's Avatar
What year Cutlass?
Old 01-10-2006, 08:29 PM
1986 supreme
Old 01-10-2006, 09:51 PM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
what's wrong with his GN? They're worth more with the turbo six than the v8.
Just curious.
I also wondered about using a modern 3800v6 from a late model camaro and using it in turbocharged form, the engine is an updated version of the old 3.8s.
Old 01-10-2006, 10:05 PM
You will have no problem putting the turbo engine from the GN into your Cutlass. They are the same under the body. You will need the mounts for the GN. This is a fairly common swap. I had a friend that did a similar swap GN engine into a non GN Regal, that car was a sleeper and lots of fun.
Old 01-11-2006, 12:53 AM
Ok Thanks
Will I need to change all the wiring in the car along with the brain? Or just switch out the brains?
The reason he has the motor is because it was in his buddies grand national. They thought the coil pack was bad cause of the way it would start when it wanted too. It ended up being a loose plug under the hood but it was too late he sold the tranny and just had the motor. He is now getting a vortec 350 with a new tranny.
I am really looking forward to hooking it up too my car.
Old 03-31-2011, 10:39 PM
87 gn motor into a 86 cutlass
im tryin to do the same wat all is need to do so...
Old 03-31-2011, 10:46 PM
327NUT's Avatar
Hey Reggie...this post is 5 years old
Old 04-01-2011, 09:54 PM
where could i find dis info im askin about at then buddy n thanks
Cutlass exhaust manifolds ChrisMiddleron Engine 9 09-27-2005 04:08 PM
sbc in a 87' cutlass suspreme serg18 Engine 10 05-09-2005 11:25 PM
Bolting up core support on 71 cutlass. Wmarden Body - Exterior 1 12-23-2003 09:25 AM
Fit turbo on my cutlass cutsupreme Engine 5 09-03-2003 02:58 PM
Turbo on 3.8 Cutlass?? cutsupreme Engine 5 05-25-2003 12:11 PM
