putting on a new full vinyl top?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-31-2007, 11:24 AM
Has anyone got some fail proof advise for putting on a full vinyl top on my roadrunner? Im going to attempt this myself because the local upholstery places around where I live like to rip people off....im very tired of people taking advantage of car people like myself...anyways Im very nervous...dont want to @#$% it up.
Old 06-01-2007, 08:47 PM
bluestang67's Avatar
Last journal entry: rear end detail
Never did it myself but i know it can be done like the pros . Get the 3M vynle top adhesive in a spray can , Spray is easier to use then the quart can and a brush. I would spray about a 12 inch wide strip in the middle coating roof and material. Stick it down pull it up and flash it just a few minutes then rub it down real good. Then work your way out on both sides. One thing is dont get cheap on the glue and you should come out fine .
I used these products back in the 70's and 80's to do vans. You will need a well ventilated area this stuff is very potent in its vapors , or better yet wear a good mask to work with it.
Old 06-01-2007, 09:23 PM
302 Z28's Avatar
If you want it to last do not use any adhesive from a rattle can. DAP makes a sprayable Landau top adhesive that has a tenacious grip.
Vince
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
POLL: What color for vinyl top on this car....SEE PICS.. STATUTORY GRAPE Body - Exterior 8 02-23-2007 07:04 PM
Removing vinyl top on nova 1quiknova Body - Exterior 4 10-05-2005 11:31 AM
