Putting power steering on a 41 olds... Help - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-12-2012, 06:00 PM
Im going to put power steering on my 41 olds. Can anybody suggest a good gearbox to use any other help would be greatly appreciated. I'm using the stock frame and the stock steering components and suspension but I'm running a Chevy 350 .
Old 06-27-2012, 04:58 PM
BigChevyFTW
Guest
get a gearbox from a jeep cherokee it has a good ratio and will help that boat turn better!
Old 06-27-2012, 05:48 PM
Wiki Edits: 27
gear box
Or a Toyoto or other import truck.
Old 06-27-2012, 08:12 PM
If you run an import box is it possible to run GM pump or will you need to make brackets for import pump. Will import pitman arm fit early american drag link?
Olds 455 engine power steering roggera Engine 1 02-20-2007 03:57 PM
Putting on new air bag steering wheel on a older steering collumn. CruisingRam Interior 10 12-20-2004 03:34 AM
olds aurora power steering noise? J. Eaton Electrical 1 11-28-2004 05:37 PM
anyone know anything about putting power brakes and power steering on a '63 impala SS Benni520 Suspension - Brakes - Steering 0 10-14-2002 01:22 PM
