Putting sbc in 1991 S15, which transmission? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-09-2011, 06:21 PM
2006strat's Avatar
Braggen won't get you anywhere
Putting sbc in my 91 S15, and was wondering if there is a close trans *ex,th350,700r,th400, out there that is close to fitting with out having my drive shaft cut? Mild SBC 400hp maybe at most. 3000+ stall.
Old 03-09-2011, 06:28 PM
Wiki Edits: 31
700- R4 should work.
Old 03-09-2011, 08:07 PM
ericnova72's Avatar
More for Less Racer
What engine and trans combo was in there originally??
Old 03-10-2011, 05:32 PM
2006strat's Avatar
my s15
its the 2.5l iron duke and 5spd...
Old 03-10-2011, 06:23 PM
i put a turbo 350 in mine at first same shaft 85 s10 short bed. but the 373 gears made me drive on the highway at about 3500-4000 rpm went to a 700r4 had to shorten the shaft and remake crossmember to keep pinion angle correct. running about 500hp broke the 700 9 times before i got it right. but found an link in hot rod magazine on how to make one that can handle hp. worked great for 2 years. but now have dana rear from corvette with 308 gears and am getting ready to go back to 350 or maby 4 speed stick.
Old 03-10-2011, 07:41 PM
ericnova72's Avatar
More for Less Racer
V8 and TH-350 fits here with no mods the crossmember or driveshaft. 200R4 will fit the driveshaft but will require the crossmember moved back as the mount location is farther back on the case than a TH-350.
Old 03-10-2011, 07:57 PM
2006strat's Avatar
S15
So in my 91 the sbc and a th350 will drop in no problem? No shorting of shaft? I just want most everything ready before I drop one weekend then have to wait a week to get my drive shaft. I won't be pushing over 400hp for sure just a cruiser....
Old 03-11-2011, 04:59 AM
a th350 will fit in with no driveshaft mods if its the 9 inch long tailshaft version. if you have the more common 6 inch long tailshaft your driveshaft will be 3 inches too short. it will not for 100% bolt in for the crossmember.
a 700r4 will be a 100% bolt in as far as the driveshaft and crossmember is concerned
1991 chevy 4x4, 350 engine, transmission swap? blurrydan Transmission - Rearend 1 01-11-2010 05:52 AM
putting motor to transmission 49fordp/u Engine 6 11-16-2008 08:48 AM
1991 Gmc elrod46 Introduce Yourself 0 10-31-2008 07:46 PM
1991 Chevy Truck transmission seal leak D0UG Transmission - Rearend 5 08-01-2008 07:59 PM
1991 Chevrolet K2500 4X4 transmission problems Craig Eppley Transmission - Rearend 15 02-25-2008 05:02 PM
