Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Putting together a 9 inch Rearend trouble please
Old 09-25-2012, 11:54 AM
big gear head's Avatar
big gear head big gear head is offline
High Performance Rear Ends
Are you talking about the pinion nut? If you put in a new crush spacer then you will need to clamp the yoke down tight in something strong enough to hold it while you put around 300 foot pounds of torque on the nut to crush the spacer. You will probably need a 3/4 inch drive breaker bar with a cheater pipe on it. Crush the spacer until you get about 19-22 inch pounds of preload on the bearings.
