-   -   Putting together a 9 inch Rearend trouble please (http://www.hotrodders.com/forum/putting-together-9-inch-rearend-trouble-please-224360.html)
sbrnmhll 09-25-2012 08:25 AM
When I try to tighten it down the bearings r sloppy the nut bottoms out before the bears tighten
lmsport 09-25-2012 08:59 AM
If you have a "Daytona" yoke and regular pinion bearings, you will run out of spline when trying to preload the pinion bearings. You can buy a spacer from Randy Ring and Pinion to use with a Daytona yoke that will make it work, or a new yoke.
big gear head 09-25-2012 12:54 PM
Are you talking about the pinion nut? If you put in a new crush spacer then you will need to clamp the yoke down tight in something strong enough to hold it while you put around 300 foot pounds of torque on the nut to crush the spacer. You will probably need a 3/4 inch drive breaker bar with a cheater pipe on it. Crush the spacer until you get about 19-22 inch pounds of preload on the bearings.
