Putting together a 9 inch Rearend trouble please - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-25-2012, 07:25 AM
When I try to tighten it down the bearings r sloppy the nut bottoms out before the bears tighten
Old 09-25-2012, 07:59 AM
If you have a "Daytona" yoke and regular pinion bearings, you will run out of spline when trying to preload the pinion bearings. You can buy a spacer from Randy Ring and Pinion to use with a Daytona yoke that will make it work, or a new yoke.
Old 09-25-2012, 11:54 AM
big gear head's Avatar
High Performance Rear Ends
Are you talking about the pinion nut? If you put in a new crush spacer then you will need to clamp the yoke down tight in something strong enough to hold it while you put around 300 foot pounds of torque on the nut to crush the spacer. You will probably need a 3/4 inch drive breaker bar with a cheater pipe on it. Crush the spacer until you get about 19-22 inch pounds of preload on the bearings.
9+ rearend trouble TimoFinn Transmission - Rearend 11 02-21-2011 08:17 AM
9 inch rearend issue 18camaro Transmission - Rearend 2 08-30-2008 01:41 PM
9 inch ford rearend martion Transmission - Rearend 4 01-22-2007 11:08 PM
9 inch ford rearend 36plymouth Transmission - Rearend 2 02-28-2006 11:23 PM
I need some input on putting a Ford rearend under a 1972 Dodge Dart onebadmerc Transmission - Rearend 7 12-21-2005 10:30 PM
