Putting together piping system for air. - Hot Rod Forum : Hotrodders Bulletin Board
View Poll Results: Which would you recommend?
Thread sealing compound? 4 57.14%
Teflon Tape? 3 42.86%
Voters: 7. You may not vote on this poll
Old 12-15-2005, 03:59 PM
58Chev's Avatar
Building a 10 footer.
Last journal entry: No more room in my garage.
I'm just about ready to start my Compressor piping system.
I am using 3/4" Galvanized Steel pipe with threaded ends.
Home Depot recommends that I use the pipe compound thread sealer sold in a can with an applicator.
Should i stick to using the sealer or is teflon thread tape OK?
Old 12-15-2005, 05:03 PM
Wiki Edits: 31
They will both work, I used teflon tape and it is fine.
Old 12-15-2005, 05:52 PM
BOBCRMAN@aol.com's Avatar
Correctly using tape is good! But some people get in a hurry or aren't great with tape and pieces of it get loose in the air system at the worlds worst times! Murphy's law.
Old 12-15-2005, 05:55 PM
Wiki Edits: 31
and some people don't pay attention and wrap it on backwards.
Old 12-15-2005, 06:04 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
For that application I prefer Rector-Seal , It does not ever get hard and it will seal good. Its good for natural gas and LP lines also.
Old 12-16-2005, 12:27 PM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
I have always used the liquid pipe dope, just stay a little back from the end of the pipe and you should be all set. Both ways would work.
Steve
Old 12-21-2005, 02:24 PM
I like Pematex non-hardening gasket sealer, works really good and will not come off in the pipe. Just what I use but there are other sealers that I am sure are at least as good, Rector-seal is a very good one. Just remember not to over-do whatever you decide on it only takes a small amount and any excess may be squeezed out into the pipe to come back to haunt you sometime later.
Old 12-22-2005, 10:12 PM
I typically use a bit of both--a light smear of dope and two wraps of tape. Keep the first thread or two empty of either though so no contaminants get into the airstream.
Old 12-23-2005, 12:29 AM
You can use either pipe dope or tape, if you clean the threads with lacquer thinner and a little wire brush, you will have a lot less leaks.
Rob
"There are questions to be answered, and answers to be questioned"
Chassis, Body Jig, Trunk Pan Pics.
http://webpages.charter.net/2manitowoc
Paint booth, Ventilation, etc.
http://www.2manitowoc.com/paintroom.html
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 12:18 PM
Got my HR.Com Security System cboy Garage - Tools 22 05-28-2005 05:15 PM
AWD system... muscarmad Transmission - Rearend 6 03-28-2005 11:52 AM
exhaust system length affect performance? smlblcks10 Engine 10 02-19-2004 04:40 PM
ditching pcv for e-vac system RS496Stroker Engine 7 09-13-2002 01:34 PM
