putting a vacuum advance distributor on a 4.9 Caddy v8 - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-24-2013, 04:14 PM
Arns85GT's Avatar
I am doing a build with a Caddy 4.9
This will be a carb'd engine and I will be using a distributor from the older 4.5 version of the engine and no ECM.
I am told I need to use this distributor with the internal mechanism from an older engine to get a free standing weights/vacuum advance. It may be the 4.1 distributor from 1983, but I am not sure and I am looking for advice before I buy.
Does anybody know which older distributor is the proper donor for this modification?
Thanks,
and BTW, I don't want EFI on this one
Old 01-24-2013, 04:18 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
The link you posted didnt work, but you are correct. If the dizzy has mechanical weights and a vac pot for advance, that is what you want.
Fact is stranger than Fiction
Old 01-24-2013, 04:45 PM
Arns85GT's Avatar
thanks, but the question still is which dizzy?
I know it has to be an Olds or Caddy pre-ecm distributor and I think it may be the one from the 4.1 Eldorado, but I am not sure. Any help will be appreciated.
Old 01-24-2013, 04:52 PM
LATECH's Avatar
as long as it has a mech and vac advance it will work. You can put a plain 4 pin module in it with a few mods.
You could almost retro fit a newer one with some older advance mechanisms i would imagine.
Old 01-24-2013, 05:12 PM
Arns85GT's Avatar
there is a correct one
I am told there is a model of Olds distributor that the guts of it will slide right into it, with simply cutting the stem a little shorter. But I don't know which Olds engine.
Old 01-24-2013, 05:23 PM
LATECH's Avatar
you will have to bust out with a few distributors and do some checking.
Joe Padavano is a HR member and a GM afficionado. He would probably know what fits...right off the top of his head.
Old 01-24-2013, 06:59 PM
Arns85GT's Avatar
there is the problem
I don't have access to a bunch of distributors to try out. I am a home hotrodder and the advice from someone like Joe would be great. I don't know his forum handle though.
Arn
Old 01-24-2013, 07:19 PM
LATECH's Avatar
Your thread has a pretty good title. Chances are he will see it and answer.
I couldnt find his exact username for a PM. But his username is what I posted.
Old 01-24-2013, 07:43 PM
Arns85GT's Avatar
Let's hope he sees it
I tried Joe Padavano for a PM and no luck
Old 01-24-2013, 09:33 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Thanks,
The Olds 307 was mentioned, but the following link is to a thread that will shed some light on it all. The Fiero forums in general have a lot of Cad info, including non feedback distributor/carb swap.
CARBED 4.9 SWAP INQUIRY - Pennock's Fiero Forum
Old 01-25-2013, 12:10 AM
I never got the PM. I don't know Caddy motors, but I've never heard of an Olds distributor fitting a Caddy. The only exception is the 76-79 Sevilles and 79 Eldo that used the 350 Olds motor (so obviously an Olds distributor fits those). The Olds uses a hex oil pump drive - all other GM distributors I've seen use a flat blade drive in the distributor gear.
More importantly, the top photo is a Caddy 4.1 distributor, the bottom is an Olds (all 1964-1990 Olds V8s use the same distributor). Do the look like they interchange?
Old 01-25-2013, 03:39 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The complete distributor isn't used. Parts are mixed/matched. Disassembly/modification required. Not plug and play.
Old 01-25-2013, 06:36 AM
Arns85GT's Avatar
I got another answer
A fellow I contacted at the Fiero Forum says I use the internals from a Pontiac v8 301 350 400 or 455. Apparently the internals just slide in.
Thanks for the info Joe, interestingly my Chevy V6 uses a hex drive on the distributor too. That is the 2.8,3.1,3.4 series
I'll keep you posted.
Thanks for the help guys.
Old 01-25-2013, 02:57 PM
LATECH's Avatar
Joe...you Da Man...
Old 01-25-2013, 06:14 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Yeah, helpful info... Joe.
Opinions on ported of full vacuum for vacuum advance ? y2k600f4 Engine 13 10-07-2011 09:38 PM
Timing... vacuum or no vacuum advance? 454ChevelleMalibu Engine 17 04-25-2010 09:37 PM
putting the distributor in the right way 70 nova Engine 29 08-27-2004 09:17 PM
ok to use same vacuum line for vacuum advance and tranny vacuum modulator? brian400ex Engine 4 02-19-2003 02:25 PM
computer advance or vacuum advance?? 1984camaroZ28 Engine 1 10-12-2002 02:57 PM
