PVC board didn't work out, Need help forming large, curved panel (Pics)
I bought a 4x8 sheet of 3mm PVC board and practiced making bends on it and was real happy with it but when I tried it to make the back panel on the inside of my cab, not so good! I didn't realize how there was actually a compound curve as the bottom of the cab swoops back. Here is my progress:
![]() ![]() The panel will be visible but barely and my plan was to cover it in vinyl to match the seats. No design or anything complicated. I'm wondering if fiberglass might be the only solution but hoping not because I don't have much experience with it. This would require a huge mold! The only fiberglass resin and mat I see are at the hardware stores and it seems pretty expensive for such a small amount. A project this size would require a lot of resin and mat, yes? Hopefully, someone has another idea on how to get this done. I need help. Jeff |
That would be alright but the truck isn't running yet so I probably couldn't take the truck to a shop. I wonder how they would get the metal to flare out at the bottom? Where in TX is this shop?
Seems like this shouldn't be so complicated but waiting for other ideas! |
This company, http://www.tapplastics.com/ sells fiberglass supplies, and plastic supplies.
If you decide to go with fiberglass, you can get fiberglass, and resins at much better prices than buying small bits and pieces of fiberglass supplies at hardware stores. |
Jeff,
They would have a roller press to bend the angles as needed. It is really simple. You just move the sheet metal to a different angle then roll press the curve into it. I think the problem you are having is trying to figure out how to make the bend flair out wider at the bottom. It is really easy to do. Just angle the sheet and bend it. For example instead of putting the sheet in square with the press you would put it in askew, or at an angle. Then bend the sheet as needed. It would take a bout ten minutes to make this piece for the truck like in your pictures. I made one myself similar to this at home for my 68 Chevy truck. I got a 6" piece of PVC pipe and marked the angles as needed. (wider at the bottom) Them I laid the sheet metal flat on the driveway and put the PVC on top of the sheet where I had marked it. I got a friend to hold each end of the PVC pipe and simply bent the sheet metal over the PVC pipe. It worked great. The trick is DON'T cut the sheet until AFTER you bend it. If you cut it first it will be short on the bends. (unless you can do the math to figure the curve) If possible it might fit better if a shop did this but you could do it at home yourself. The shop is in Dallas. I can't remember the name of the shop. I'll have to get that next time I go by there. They have been there since the 60's. ______________ Ferrari Killer Steve |
I sent you a PM I don't know if you got it or not.
Check out https://twitter.com/#!/SullivanMtrspts This is not the shop I was telling you about before. I can't find their info. I know the guys at Sullivan Motorsports as well. These guys are VERY Good and can make what you need. They are in the Royal Lane and 35 area in Dallas. From their Twitter: https://twitter.com/#!/SullivanMtrspts Terry Sullivan Racer and Owner Racing Transmissions and Components Chassis Shop Currently Running Super Gas/ Super Comp NHRA 972-406-3993 _________________ Ferrari Killer Steve |
I know I have not been on this site for awhile but what happened to all my old post? It looks like I am a newbie here.
Did something happen and the post count got deleted? _______________ Ferrari Killer Steve |
I think most of your posts wer in the "Lounge" area.
Those posts do not count as posts---I guess it may be a technical point of view. |
Thanks Bryan, that may be the case.
We had a car stolen and it (the theft) was posted on this site. I can't remember but I think that was in the "lounge' area. Maybe I need to read other post here more often. ![]() _______________ Ferrari Killer Steve |
First find the center of the back window, make a mark with a sharpie at the bottom center of the window. Transfer this mark straight down to the floor. Then measure from the mark at the center of the window over to where the curve starts. Do this on both sides of the center mark (these should be the same distance, side to side) and transfer these marks straight down to the floor. Take some poster board and cut it into 1" to 2" wide strips. Using the marks at the curve attach one strip straight up and down with magnets or tape. Place another strip straight up and down to the other end of the curve at the B pillar. Here's where one of my favorite tools comes in, a hot glue gun. Using the hot glue attach strips horizontally overlapping between the two vertical strips pushing them into the shape of the curve, one at the top and one at the bottom, at least, with a couple more equal distance apart. When the glue sets remove the strips from the truck. You now have a pattern of the curve. The pattern might lay flat, but probably won't so you'll have to play around with tracing it out on a full sheet of poster board while you roll the pattern out. Now cut the traced pattern out of the poster board and see how it fits, this should have gotten you close and if your really lucky will fit the other side as well when it's reversed. Once you have it fitting how you like just measure up the rectangle under the window and add the pattern shape to the ends. I've read this over a dozen times, I think it makes sense...........
The seams can be glued together on the front and back with some kind of thin man-made fabric like Versare.
__________________________________ No one lives forever, the trick is creating something that will. __________________________________ |
Making the panel in multiple pieces is the easiest way to go. When you have all the pieces fitting properly, they can be glued together with PVC cement. The PVC board is fairly easy to manipulate with heat, so you really shouldn't have many problems.
Schlock Rod |
Is the PVC panel more brittle than a ABS panel?
No, PVC foamboard is not at all brittle, and it's way less expensive than ABS.
| Recent Interior posts with photos |
| Wanted: Bright yellow large flake work-up | GasedX | Body - Exterior | 6 | 01-07-2007 08:04 PM |
| panel forming | home brew | Body - Exterior | 7 | 07-04-2006 08:38 PM |
| Forming a curved flange without a shrinker or stretcher | John Kelly | Body - Exterior | 9 | 02-18-2006 07:28 AM |
| '53 Stude interior progress... (large pics) | phattpat | Interior | 1 | 05-18-2004 07:38 PM |
| A few pics of my '54 GMC 1-Ton Panel Van | DesertPanel | Hotrodders' Lounge | 10 | 10-10-2003 01:38 PM |
