-   Interior (http://www.hotrodders.com/forum/interior/)
-   -   PVC foam board (http://www.hotrodders.com/forum/pvc-foam-board-195959.html)
cajun1955gmc 04-07-2011 08:48 PM
PVC foam board
Can you sew through pvc foam board?
Thanks
DanTwoLakes 04-07-2011 08:58 PM
Yes, no problem. In fact it works very well, and is as easy on the needle as waterproof panel board, and easier on the needle than plywood.
cajun1955gmc 04-07-2011 09:23 PM
pvc foam board
Thanks Dan
DanTwoLakes 04-08-2011 08:34 AM
When you do your sewing, sew slow, don't try to rush it. It's also a good idea to use larger stitches, like 5 or 6 to an inch.
