PVC foam board, fiberglass lay-up? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-26-2011, 02:02 PM
Does anyone know if pvc foam board and fiberglass are compatible? I can not find a msds or tech sheet for the product I have. Anyone have success laying up fiberglass on pvc foam board. I googled it and came up short on a reliable answer. Thank You in advance, JCAR
Old 07-26-2011, 02:06 PM
I think the resin will melt the foam. But one sure way to find out, mix some up n mop it on and see what it does.
Old 07-26-2011, 02:25 PM
Yep, that is exactly what I am about to do. I was just wondering if anyone has been successful at it, tips, tricks, etc. I don't always realize something is impossible right away!! JCAR
Old 07-26-2011, 03:20 PM
DanTwoLakes's Avatar
Wiki Edits: 22
I don't think the resin will melt the foamboard, but I don't know for sure. I do know that it is heat formable and will withstand temperatures in the 250* range. Did you post your question on Fiberglass Forums? Here's the link: CLICK HERE
Old 07-26-2011, 08:12 PM
Last journal entry: Getting Started with Upholstery
I wish I could find PVC foam board in the Portland, OR area. Any one have any advice on finding a supplier?
Old 07-26-2011, 08:37 PM
Wiki Edits: 22
Any sign shop or plastic supplier should have it or be able to get it. Like this place: CLICK HERE Click on "Plastics" then "Sheet" then scroll down to PVC. PVC foamboard is also called expanded PVC or closed cell PVC, and the brand they handle is Celtec.
Old 07-27-2011, 08:41 AM
shine's Avatar
SPI Thug
Last journal entry: some progress
dan , what thickness do you use most ?
Old 07-27-2011, 08:49 AM
life is a temporary assignment
I use the green stuff at hobby lobby.... That is used in the bottom of a flower pot... Work's very good and easy to sand..
Old 07-27-2011, 09:04 AM
Wiki Edits: 22
I use 3MM (about 1/8") and 6MM (about 1/4"). I use the 3MM the most by far to make panels with. It cuts with regular woodworking tools. If you want to drill holes, especially large holes, Forstner bits work the best.
Randy: This stuff is solid, and comes in 4' by 8' sheets, it's not like the stuff in the bottom of a flower pot.
Old 07-27-2011, 09:12 AM
shine's Avatar
SPI Thug
thanks dan. i have a car coming up that i am doing the interior . it is one i am building to sell and will be pretty exotic inside.
46 ford sedan, top laid down 3 in in front , 108 in wb ( same as vette ) 59 chevy dash , mostly painted metal inside. will use the foam board to make all the panels. at least i hope i get it done. first complete interior .
Old 07-27-2011, 09:13 AM
Yea... I know what your talking about Mr. Dan...Just wanted him to know it's also good for laying up fiber glass....Sorry.. I jumped in with something a little of topic..
Old 07-27-2011, 10:15 AM
Wiki Edits: 22
I knew what you were talking about, Randy, and so did Shine. You're right, the green flower pot stuff is great for fiberglass forms.
Old 07-29-2011, 01:41 AM
Thank you, Dan!! I picked up a few sheets of the 3mm today. This stuff is great to work with! And the price was very good I thought.
Old 07-29-2011, 07:02 AM
Wiki Edits: 22
I pay about $26 for the 3MM 4' by 8' sheets. My supplier also has 5' by 10' sheets. If you drill large holes in it, use Forstner bits if you have them, or spade bits, but go real slow and/or put a backer board under where you drill. Auger bits seem to tear it up.
Old 07-29-2011, 11:56 AM
Thank you for the information, as always!
They sold it to me for $26/sheet for white.
PVC foam board cajun1955gmc Interior 3 04-08-2011 08:34 AM
Gluing foam and fabric to Sintra board? jimchevy Interior 8 06-23-2008 12:33 PM
foam for fiberglass mold stea Interior 7 08-17-2006 05:25 PM
Fiberglass interior using foam..... Jackyl666 Interior 8 07-28-2005 11:23 PM
headliner board foam malibu350 Interior 7 07-24-2005 12:06 PM
