PVC Valve - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-27-2011, 09:44 AM
PVC Valve
OK OK I have seen a lot of post today about PVC Valve placements. I have a question
I do not have a PVC Valve installed on my 79 SBC 350; currently I have a breather coming off one of my valve covers with a tube that vents to the bottom (Outside) of the frame. Is this hurting my performance any? The motor seems to run great, just curious about this.
Thanks
Old 04-27-2011, 10:50 AM
busted knuckles
No, your carb'd 350 is fine, I wonder though, do you have a hole on each valve cover?, on my 78 350 I have two oil breather caps, one on each side.
Old 04-27-2011, 11:11 AM
benwantland's Avatar
Your setup is probably "good enough", but - there's no reason NOT to run a PCV on a street engine. For one thing, a lot of breathers just have steel wool or something similarly coarse in them for filtration, which is fine when they're exhaling, but what about when air outside air moves through that breather into your motor? Lots of dust and crap that you don't want inside your engine. Plus, your draft tube is going to be puking oil out onto the underside of your car (which I guess is helpful for corrosion control), as well as your garage or trailer floor, the street, the track staging area, etc.
And a properly functioning PCV system (PCV valve on one side, breather drawing filtered air from your air cleaner on the other side) will reduce oil leakage & emissions, while theoretically improving your ring seal slightly, due to the vacuum in the crankcase (not technically a vacuum, but lower than atmospheric pressure). They're cheap and simple. I'd run one. You do what you want.
Old 04-27-2011, 01:02 PM
ductape&monkeywrench,
I also Have antoer breather on the otherside as well,
benwantland,
Thank you for the information I will look into getting the PVC setup and intalled
Thanks Guys
broken valve? valve spring is sitting off center from rocker tip. zoomo Engine 63 03-25-2011 08:37 PM
how do i measure valve seat for valve head diameter? 406 ss monte Engine 2 04-07-2010 09:36 AM
isolator valve, sleeve, regulator valve for 4l60e? mike 96 ws6 Transmission - Rearend 28 01-29-2006 11:16 AM
Is this (bigger) valve sitting right afte the new seats and valve job? sizemoremk Engine 16 12-11-2005 12:18 AM
Can the dual coil valve springs on a BB destroy Valve guide seals Auto-Part Engine 4 11-25-2003 05:23 PM
