Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - pwr brake booster issues?
Old 06-12-2007, 08:29 AM
Frisco's Avatar
Frisco Frisco is offline
Glad To Be Here
Originally Posted by Dgas
I bought a new MC w the correct piston Dia. + rod hole (Deep) in the primary piston and a used 68 Chevelle Booster
Master cylinders with the DEEP push rod hole are usually used with no power assist.
Master cylinders with the SHALLOW push rod hole are usually used with power assist.
Sounds like you have the wrong master cylinder for your application.
