Q: about 3speed manual collumn shift linkage. - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-24-2006, 12:04 PM
jezbo78's Avatar
looking for the part #/name of the bushing or whatever keeps the linkage tight. its very loose and sometimes won't go into gear. i've heard through the grapevine that this is a common problem with 3 speed transmission. any diagrams or info would help. here is a pic. 1971 c10.
thanks
-Jesse
Old 11-24-2006, 02:23 PM
MR. Gasket has a bushing kit part #11
Bob
Old 11-25-2006, 12:59 AM
This bushing or grommet should still be available for your truck at your local Chevy/GMC truck dealer's parts counter for less than $5.
It was probably used without chnage from the 50-80s when standards went back to the floor for shifting.
Old 11-25-2006, 08:43 AM
jezbo78's Avatar
thank you both very much. ill check on both options today. thanks again.
-Jesse
Header collector in way of column shift linkage Warrant Engine 4 08-29-2006 01:26 PM
TH 350 1-2 Manual shift Feel HarderTranz Transmission - Rearend 3 05-16-2006 10:20 PM
best way to adjust shift linkage? lemans-tom Transmission - Rearend 2 09-08-2005 03:54 AM
4L80E diesel computer 5foot2 Transmission - Rearend 2 04-09-2005 01:48 PM
th350 1st gear manual shift problem desman Transmission - Rearend 6 02-08-2004 04:15 PM
