Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Q About Zipper Foot
  #28 (permalink)
Old 03-17-2007, 05:59 AM
fordSR fordSR is offline
Generally when I bind carpet there is no visible stitching. I just use the standard method by stitching the binding on the top side then folding it over the edge and gluing on the backside. I do use a guide attached to the bed of my machine for a uniform width. The carpet edge of course, must be trimed straight. I have several binders, some that I made and some that I bought from CutSewService. I use brass shim stock about .040 thick for any attachments that I make. This is easy to form and can be soldered to a heavier brass plate where it screws to the bed. I'm sure you could make a carpet binder to suit your needs.
