Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Q About Zipper Foot
  #36 (permalink)
Old 03-18-2007, 05:50 PM
armysniper armysniper is offline
Vini Vidi Vici
Dusty one thing that might help with the control issue is this.
At the top of the treadle bar, up near the motor, there should be a wingnut that pre-loads a spring. If you loosen that spring the motor should engage with less sensitivity, and more control.
I don't know if all machines have that, but the few I have owned do and should help you out.
Also, to get uniform widths and stitches, use the foot as a guide. WHat do you mean mark? Well, since you asked, when doing a wide frech seam, (seen on most american and late model cars) I place the inside of hte foot right on the seam. And keep it there as you sew. On narrower ones (seen in higher end cars) I move the seam to the outside of the inner foot and keep it there. it's only about an 1/8th in. difference but the visual is huge.
Hope the makes sense.
