Q jet B port ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-09-2007, 03:49 PM
fast68's Avatar
likes chevy trucks & boobies
Q jet B port ?
anyone know what the B vacuum port on the front of the Q jet carbs was for ? it seems to run to somewhere in the passenger side primary venturi of the carb, or somewhere in there
thanks
Old 02-09-2007, 09:59 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
If it sources below the throttles its manifold
If it sources immediately above the throttles its ported.
Many Qjets had a higher vacuum source just below the boosters that was a venturi vacuum. It was used for multiple reasons over the years, most of them dumb
Some Qjets also have a positive flow source above the boosters on the secondaries that should not be confused with a vacuum source. Its a positive flow that draws warm air over the Thermostatic air door in the snout of the air cleaner.
head flow velocity and port size 71javelin Engine 40 04-22-2006 12:32 PM
Port CFM vs. Valve Size vs. Port Velocity...Data WANTED! Elevinpointsixtoone Engine 45 04-17-2006 12:37 PM
Timing Port Dilemma copndoc3 Electrical 1 01-22-2006 09:44 PM
Where is manifold vacuum port on Quadrajet 4mv? dr-data Engine 10 12-13-2005 04:41 PM
Timed Vac Port or Manifold Vac Port Sweet-34 Electrical 14 04-27-2004 04:35 AM
