Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Q-Jet Confusion
Thread: Q-Jet Confusion
Old 10-15-2004, 03:36 PM
docvette's Avatar
docvette docvette is offline
Wiki Edits: 12
sec. Jet height.
Doc here
Had something like that before on my Vette...It kept failing smog on the low speed dyno pull, but was good at high speed dyno..
Turns out the secondary Needle Hanger (part #12 on the photo)was bent (both rods wern't at the same height) so when it was seated on one the other was passing fuel.
I assume the stock air cleaner had something to do with the deformation, since after I got the needle hanger level again, and installed an eldebrock air cleaner, it never happened again...and It passed smog after...and got much better mileage!
Just a thought..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
