Q-Jet Insulator/Base gasket - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-05-2008, 01:35 PM
I am preparing to install a 1971 Rochester Quadrajet on an Edelbrock Performer Intake. A couple questions: 1) Is it required that I install an Insulator between the carb and Intake? 2) If yes; then is it required to also install a base Gasket on each side of the Insulator? (Insulator is 1/4" thick and is made from what looks like pressed gasket material.)
Old 10-05-2008, 01:59 PM
SSedan64's Avatar
The Edelbrock intakes with exhaust crossover are bad about transfering too much heat to the carb. Many block the crossover completely to prevent this. If you haven't installed the intake yet. I'd at least use restrictors in the exhaust crossover.
You should use the insulator gasket. You don't need a base gasket on either side of it. It acts as a gasket & insulator.
Tip: Rub a little Vaseline on both sides of the insulator gasket to make removal easy next time.
Mr. Gasket Arcuden Engine 12 10-02-2007 04:27 PM
Percy xx carbon exhaust gasket material - passed my first (and second) stress tests lowROLLERchevy Engine 6 02-17-2007 09:29 PM
Beware of one piece oil pan gasket for a Ford 460..... onebadmerc Engine 0 12-30-2006 06:00 PM
Changing pan gasket on 350 chevy rapsag Engine 16 08-04-2005 07:55 AM
Clearance/head gasket questions hlweyl Engine 16 01-31-2004 03:53 AM
