Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Q-Jet Metering Rod Idea
Old 09-16-2003, 01:53 PM
NorthStar's Avatar
NorthStar NorthStar is offline
You can adjust the primary side using PTA screw, a small amount changes the jet area a LOT so go easy. That will give you the good gas mileage. When picking a set be concerned with the tip diameter thats what will keep it from pinging at light throttle.
On the secondary side just find a set stamped DA theyll work good.
