Q jet need help in setup - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-14-2013, 08:21 AM
RWENUTS's Avatar
Originally Posted by joe_padavano View Post
Canadian cars didn'get the CCC system until 1985 or 86:
1984 was the first I saw. I had one on a 84 Buick Riv with an Olds 307.
  #17 (permalink)
Old 06-14-2013, 11:04 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Again- you need to use more initial. The trick is the total advance has to be limited if it goes too high w/the amount of initial you need.
AFA leaking well plugs- the tell-tail on that as a problem is if the carb float bowl empties overnight. This will usually leave a small hit of fuel in the bottom of the accelerator pump well, but unless the engine starts and runs well when cold (or has an electric pump), the engine will often stall after starting, then will take a lot of cranking for the mechanical pump to refill the bowl.
I have no idea what the percentage is of Q-jets w/leaking plugs. On the post ~1968 Q-jets, the secondary plugs are spun in then peened, so to speak. The main plugs are pressed and sealed w/a soft metal around them- and they can and do leak on some carbs, regardless of the year.
Even though Ruggles recommends Marinetex epoxy, epoxy is not the way to fix a leaking main well plug- tapping them for a machine screw works much longer- as in forever. Epoxy will eventually delam from the metal and the leak will resume.
More here.
It is very easy to set the secondary air valve to open fully.
The Following User Says Thank You to cobalt327 For This Useful Post:
raguza123 (06-15-2013)
  #18 (permalink)
Old 06-15-2013, 06:14 PM
I viewed the page and it has a lot of info, very helpful, I saved it to my pc to view when I need too.
standard q-jet and ccc q-jet fuel inlets gearheadslife Engine 2 05-03-2013 07:08 AM
Jet PErformance Q-jet tuning Mertz Engine 2 10-22-2009 01:48 PM
Jet Performance Q-jet tuning Mertz Engine 14 10-12-2009 01:42 PM
Q-jet primary jet number ??? Augusto Engine 1 08-11-2006 10:02 AM
anybody using the Jet Performance Q Jet? dion Engine 1 04-22-2004 08:02 PM
